T Tops - NCRS Discussion Boards
T Tops
  • Joseph M.
    • June 30, 1999
    • 334
    T Tops
    During Flight judging are the T Tops judged on or off the car? Tx.
    • 11608
    Re: T Tops
    On.
    They do not have to be removed.
    • Joseph M.
      • June 30, 1999
      • 334
      Re: T Tops
      Patrick, tx for the info.
      • Harmon C.
        • August 31, 1994
        • 3228
        Re: T Tops
        I think if you check the judging manual you will find they need to be removed to check the weatherstrip and all the other parts on the inside are easy to look at it when they are off. I checked every thing on the bottom at that time when I judged exterior.They are on most of the time but I had to take them off and hold them while the judges inspected them on my T-Top.
        Lyle
          • 11608
          Re: T Tops
          I've never had to remove one nor seen one removed, nor asked for such.
          Patrick
          • Harmon C.
            • August 31, 1994
            • 3228
            Re: T Tops
            If judging by the 70-72 TIM&JG it says exterior judges should judge the T-Top weatherstrip and the owner should remove them. Has any owner had to take off their T-Tops for weatherstrip inspection?
            Lyle
            • Bob D.
              NCRS Shipping Data Report Manager
              • April 30, 1996
              • 785
              Re: T Tops
              Lyle is correct, the TIM & JG says, "The owner is responsible for removing each panel so that weatherstrip may be examined." I have asked owners to remove the tops on their t-top cars when judging 70-72. Besides looking at the weather stripping I also look at the latches and the rubber tips on the latches.
                Re: T Tops
                I've never seen it done! BUT, the NCRS Judging Reference Manual DOES make provisions for judges to request the owner to remove this/that part for visual inspection. So, I won't rule out the possibility that some judges might.
                About the only place I've seen T-Tops 'dinked with' on the Judging Field is on those Shark cars equipped with anti-theft alarms and the Operations team wanted to verify the functionality of the anti-theft trigger switches...
                • Harmon C.
                  • August 31, 1994
                  • 3228
                  Re: T Tops
                  You don't need to go to the NCRS Judging Reference Manual. It's in black and white on page 48 of the fourth edition TIM&JG. If the judges are reading the book like we all do when we get moved out of our regular class it will be their. Owner removes T-Top judges check weatherstrip. All other parts interior judges.
                  Lyle
                  • William M.
                    • July 31, 1993
                    • 390
                    Re: T Tops
                    At the New England Regional, I was asked to lift them up and demonstrate the latching during Operations. During Exterior judging, I was not asked to remove them.
                    Bloomington Gold 2011
                    Corvette Magazine 9/11
                    Bloomington Gold 2013
                    Corvette Magazine 3/13
