I am restoring a 1974 L82 coupe and I am in the process of pulling the engine. I am ready to disconnect the drive shaft, called the propellor shaft in the service manual. I have removed the strap attachments but cannot budge the drive shaft. There is very little room but my guess would be I need to pull it forward to detach it from the rear, then move it back to disengage it from the transmission. Then move it down and forward to remove. Does anyone have any guidance on this? Is there a trick to getting the drive shaft to move at all initially?
Dan
Dan
