Hinge Pins and Hinge Bushings - NCRS Discussion Boards
  • William R.
    Infrequent User
    • April 1, 2003
    • 6
    Any advice on who is manaufacturing the best replacement Door Hinge Pins and Door Hinge Bushings for a 1966 Roadster.
  • Paul S.
    • June 30, 1982
    • 354
    Re: Hinge Pins and Hinge Bushings
    Common Item , Take Old Pin And Bushings To A Gm Dealer . These Pins And Bushings Fit A Lot Of Other Gm Vehicles .
    • Mike M.
      • May 31, 1974
      • 8365
      as paul notes, they are readily available from your local GM dealers. last time i needed the pins and bushings, what i got from the local pontiac/caddy dealer were pins that needed to be shortened and then pointed . however, the OD of the pins and the ID/OD of the bushings were suitable for the midyears and c-1 hinges.mike
      • Peter J.
        • September 30, 1994
        • 586
        This came up a couple of years ago and somebody mentioned trying your hardware store for the bushings. The ones I got from two of our Corvette parts catalogs were too short when compared to the oem bushings. I found correct bushings for next nothing at a local hardware supply.
