1965 327/300 Air Filter - NCRS Discussion Boards
  • Christopher P.
    Infrequent User
    • May 31, 2000
    • 12
    My current air filter is a paper filter embossed with "AC Spark Plug A353C". I can't find one in any auto parts store. The judging manual refers to a foam element with debossed "AC A 165C". What is acceptable for judging purposes and are they available anywhere?
    Re: 1965 327/300 Air Filter
    Christopher---
    The A353C air filter element was a SERVICE-only piece with respect to your application. The element described in the JG is what was originally used.
    The A353C was discontinued without supercession about 3 months ago. There may be replacements for it available from other brands (i.e. Purolator, Fram, etc.).
    I believe that reproductions are available of the original element.
    • Wayne M.
      • March 1, 1980
      • 6414
      I bought the last one back in the '80s from an ad in Vette Vues. It's now on my garage floor and has turned to black dust.
      Haven't looked at all the repops, but the original was of extrememly fine-celled foam.
      • Joe C.
        • August 31, 1999
        • 4598
        Christopher,
        Welcome aboard!
        The foam type air filter, as you may know, must be saturated with motor oil, and then THOROUGHLY squeezed out. The extent to which you squeeze it will affect both its filtration rate, and its restriction. If the proper amount of oil residue remains on the foam, there should be little to no oil collecting on the bottom of the air cleaner housing.
        Because the paper element is far superior to the foam type in both filtration and flowrate, I would only use a dry foam element for "show" purposes. I would not drive with a foam element installed.
        • Harry S.
          • July 31, 2002
          • 5258
          Like one of these????
          • Jim L.
            • 79
            Thanks Harry for showing a good product..... You know who
            Jim Lennartz - FWIW
            1963 SWC
            Duntov Award
            Bloomington Gold
            Gold Spinner Award
            Triple Crown Award
            Platinum Award in Class
            Best Restoration in Show
