For 1970:
I have a bracket under the dash between the vacuum valves and the e-brake cable where the trip odometer cable is mounted. There are two holes in the bracket that are the same size to fit the cable. Does it go in the hole closer to the steering column or closer to the door? There is another large hole toward the door. What are all these mounting holes for? My car has no options. I'm guessing A/C. The AIM is not clear which hole to use.
I also need to know how this cable is supposed to look exiting the back of the speedo. Mine looks like it makes an immediate 90 degree bend and comes down behind the steel supporting rod that connects the steering column to the door pillar. It looks like a very tight bend and may be the source of my trouble. On the other hand it does not have much of an option.
Thanks for any help.
Greg
Greg
