Restoration of Mid-year Aluminum Wheels - NCRS Discussion Boards
  • Jeff C.
    • 40
    I have a set of original '67 bolt-on wheels that are in very good shape with no damage to the aluminum or other structural repairs needed...but the paint between the fins is flaking and there is some oxidation / light scratches on the fins and rim area.
    I block off the tops of the fins and wheel edge and used a soft media blast to remove the paint and clean things up. Does anyone have any suggestions on steps to "fine tune" the tops of the fins and the outer edge of the wheel to bring back more of a uniform finish the natural shine? Would using very fine wet sandpaper (1,500 or 2,000) and then some aluminum polish work? Very detailed work, but I would rather do than sending off somewhere - especially with the value of these wheels...
    Last question - is the inside / backside of the wheel left natural aluminum finish?
    thank you very much - Jeff Cornwell
  • Bill W.
    • November 1, 1977
    • 402
    Re: Restoration of Mid-year Aluminum Wheels
    Jeff,
    I have restored these wheels for many years and while it is time consuming it's not hard work.
    Start by removing ALL paint from between the fins, if you don't and paint over these areas your finished product will appear mottled. If your wheels need any welding now is the time to address this. Check wheels for strightness, any good tire shop can do this at minimal cost. I use 220 grit wet/dry paper to finish the fins and outer rim, use it wet. Clean wheel with a good cleaner. Mask the fins/outer rim with tape and spray with whatever paint you think matchs what KH used. There will be slight overspray only on the back side when you finish. I like to finish by applying a light coat of wax to the machined surfaces, this will help prevent water spots. Bill
