Trans Tag ID Help - NCRS Discussion Boards
Trans Tag ID Help
  • Rich P.
    • January 12, 2009
    • 1361
    Trans Tag ID Help
    I know they are not 63-67 corvette but wanted to know if anyone could help with further.
    Thanks, Rich
  • William C.
    • May 31, 1975
    • 6037
    Re: Trans Tag ID Help
    I believe the different part numbers among other things told what the Speedo drive setup was in the trans.
    Bill Clupper #618
    • Wayne M.
      • March 1, 1980
      • 6414
      Thanks, Rich
      Well you have a couple of "possible" Corvettes in there:
      Looking in Rev 7-1-69 of Chevrolet P&A30, and '68 catalog (first ed. Sept '67); Gr 4.003:
      tag 3950356 is '69 Corvette (exc. P/Trac), and Pass. (exc. reg. fuel. P/Trac). $322.00
      tag 3946798 is Corvette-only, 4 different '69 variations (probably speedo gear, as Bill says), all close-ratio; same price. Ask me if you want me to type out all the possibilities .
      (possibly) tag # 3870357 (if 2nd last number is a 5 in tag of top right column -- hard to see) wide ratio Corvette and Passenger, if it's a '5'.
      The 3841435 is probably '64 or prior; the ones with the suffix letters are around 1970 or later. The one that begins with '9' is non-Chevrolet (another GM division like Pontiac).
      Another hint is to look in the M20/21 and G81 sections of the Corvette AIM's of various years.
      • Rich P.
        • January 12, 2009
        • 1361
        Bill and Wayne,
        Thanks. Wayne I'll let you know if I need more info.
        Rich
        • Bruce T.
          • February 1, 1978
          • 60
          3870357 is in my 66 Chevelle and El Camino AIM
          M20 13817-67 RPO L-34 + L35
          This Muncie M20 was used in the Chevelle SS 396 with either the 360HP 396 or the 325HP 396. It would also be used in the El Camino with a L34 or L35. Interestingly, the Muncie M20 used with the L78 375HP engine had a different number.
