I am missing the outboard seat belt boots from my early '66 L79 coupe. Since I have the 430 trim (green) I have had no luck finding replacements. I am wondering if anyone has dyed or otherwise changed the color of these plastic boots and what color is best to dye green and what dye/paint to use. Thanks.
Changing color on seat belt boots
Tags: None
- Top
Re: Changing color on seat belt boots
You'll find vinyl spray paint at most auto parts stores as well as auto paint supply outlets. The 'trick' is doing the job at correct ambient temps (70F or better) AND getting the plastic surfaces properly prep'd before you shoot the plastic paint. Most auto paint supply outlets will have a companion product (plastic surface prep) on the shelf adjacent to their various vinyl spray paints.
BUT, if the plastic item comes into contact with other surfaces (e.g. you sit on it, it rubs against something else), the longevity of the painted surface isn't typically that durable. The seat belt boots DO tend to rub against the side of the seat and the inner lip of the door sill...- Top
Thanks for the advice, think I will keep looking for green ones since the boot is in such an active place.You'll find vinyl spray paint at most auto parts stores as well as auto paint supply outlets. The 'trick' is doing the job at correct ambient temps (70F or better) AND getting the plastic surfaces properly prep'd before you shoot the plastic paint. Most auto paint supply outlets will have a companion product (plastic surface prep) on the shelf adjacent to their various vinyl spray paints.
BUT, if the plastic item comes into contact with other surfaces (e.g. you sit on it, it rubs against something else), the longevity of the painted surface isn't typically that durable. The seat belt boots DO tend to rub against the side of the seat and the inner lip of the door sill...Big Tanks In the High Mountains of New Mexico- Top
