Thermostat housing, 300HP base engine - NCRS Discussion Boards
  • Herbert L.
    • August 31, 1987
    • 13
    Re: Thermostat housing, 300HP base engine
    Thanks - Just a few days ago, in 2010, my friend destroyed his 300 HP fuel line while attempting to wrap it over the wrong housing, the one mentioned in the "Yellow" judging guide...
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1464
      Hi Guys...
      I did a silly thing, I actually referred to the TIM & JG for '66 & '67.
      They both state and describe the 660's as being TFP for the base 300 HP engines.
      HaND
      • Ronald L.
        • October 18, 2009
        • 3248
        #18
        John,
        Torque down cracking on the early ones?
        Are there any other revisions noted on the drawing?
          Originally posted by Ronald Lovelace (50931)
          John,
          The drawing was released on 2/1/65, and the only revision of any consequence added a second optional construction which added a circular bead with a width of .06" and height of ..008"-.015" around the two bolt holes, on the bottom side, on 9-9-68. The first optional construction added the hose retention bead at the end of the neck, and the base drawing had no bead at all at the end of the neck.
          • Ronald L.
            • October 18, 2009
            • 3248
            #20
            I know where there is one of those with next to nothing hose retention on it, that one was on my 1st 66BB late fall 1965 built car.
