Oil Pressure - NCRS Discussion Boards
Oil Pressure
    • 15610
    Re: Oil Pressure
    It would be more descriptive to say you use C-category oil, however, the 15W-40 viscosity grade is unique to this category, so it goes without saying to those who understand...
    Most 10W-30s are SM for modern cars with "roller everything" valvetrains. C-category 10W-30 is available in some brands (like Chevron Delo), but it's not commonly available at typical consumer outlets.
    Big blocks use the same lifter as small blocks, but with higher valvespring forces, it's even more critical than with small blocks to use modern oils that are best formulated for vintage engines.
    The OP should be more concerned with the service category oil he is using than his indicated oil pressures, which appear to be within the range of the GM spec in the '67 AMA specs that I have, and I expect the '70 spec is the same.
    • Joseph M.
      • June 30, 1999
      • 334
      Re: Oil Pressure
      Duke, tx for the comments on my oil pressure and the education on the different oil designations. You related the c category is not available at "typical" retailers, so where might I be able to purchace that particular oil.
      Are there internet sites that might carry the c oil?
        • 11608
        #18
        Re: Oil Pressure
        C Category oil is available "almost" everywhere (Wal-Mart, AutoZone, Advance Auto, etc), however not in the 10W-30 weight. Most common is the 15W-40 and 20W-50. Many of us use the 15W-40 without any issues, and local auto parts stores can often order you in 10W-30 if you really want it.
        Patrick
        • Joe R.
          • May 31, 2006
          • 1822
          #19
          Re: Oil Pressure
          Here's a link to Duke's article on oil (scroll down to page 3):
          Network Solutions - Original domain name registration and reservation services with variety of internet-related business offerings. Quick, dependable and reliable.
          Joe
          • Joseph M.
            • June 30, 1999
            • 334
            #20
            Re: Oil Pressure
            Joe, thank you very much for the article. It is very informative. I'll now pay closer attention to my choices when making future oil purchases.
            • Joe R.
              • May 31, 2006
              • 1822
              #21
              Re: Oil Pressure
              Joe,
              You're welcome. After wiping a cam lobe, I've been doing my research to try and avoid that happening again!
              Joe
