Joe, I pick up a gas cap for my 72 coupe, what does the correct plating look like? this one appears to be a dull silver finish, has the smooth other ring and smc logo cork gasket as the jm says , What do you think? thanks Ed.
72 gas cap question- Joe L.
Re: 72 gas cap question- Joe L.
Assuming that it has the correct embossed lettering, it sounds about right except for one thing: I don't ever recall seeing one of these with a cork gasket. All that I have seen have a black rubber gasket. I don't recall seeing it described as cork in the JG, either.In Appreciation of John Hinckley- Top
Terry-----
Examples of the GM #3994339, the L71-74 gas cap that I've seen have definitely all had the "gold" dichromate finish. However, I'm less sure that very early examples of the 3994339 had this finish. If someone comes up with an apparently original 3994339 that doesn't have or appear to ever have had a dichromate finish, then I would say early examples of the 3994339 probably didn't have said finish. Certainly, later examples of the cap, still available to this day, have the dihromate finish.
I don't think this cap was ever available in the aftermarket. If, by chance, it was, I would expect that the same Stant-manufactured cap was what was available.In Appreciation of John Hinckley- Top
Ed-----
Assuming that it has the correct embossed lettering, it sounds about right except for one thing: I don't ever recall seeing one of these with a cork gasket. All that I have seen have a black rubber gasket. I don't recall seeing it described as cork in the JG, either.- Top
I will look at gasket it appeared to be cork but may indeed be rubber, I thought the same as Terry with the gold diachromate , but it has the original plating- dull silver, smooth outter ring and smc marking. I think it maybe possiable replacements were the diachromate.I did look again at gasket, it is rubber.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Joe I saw a NOS cap in a Stant box this weekend, cadium dichromateDick Whittington- Top
My original September 13, 1971 assembly '72 has the original gas cap, cad plated (dull silver) with a black rubber gasket.Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.- Top
the original was dull cad with black rubber gasket. the replacements, that you can still get today, are gold dichromate. i have a nos cap that is dull silver cad. the old original cap on my 72 is also dull silver cad. the same goes for the cap on my 70.- Top
The current JG books say '71-72 caps are straight dull cad with black rubber gasket (early '71 have 'Caution Open Slowly add-on label while late '71 and all '72 had this warning embossed) and '73 is the first call out for caps with a dichromate wash, gold finish...- Top
