In going through my '66 L79 coupe, I now need to tackle the tough stuff, like the emergency (parking) brake warning light on the dash. The light does not work. But before I buy a new switch, bulb, etc. I have tested the single wire coming into the switch at the base of the brake shaft and it shows no voltage. I am assuming it should, since when it is closed (out) the brake is engaged and the light on the dash should light, right?
Also, there is a light bulb hanging down behind the instrument cluster with a beige socket that is on whenever the ignition key is on. I am worried this is the emergency brake light that was pulled from the upper dash mount and was driving the previous owner nuts with the red "brake" light on all the time!
Any help in diagnosing this is welcome. I am sure putting that bulb back in the mount on the upper dash will test my back!
