68 2 Questions heater core and oil line - NCRS Discussion Boards
  • Joseph C.
    • April 1, 2006
    • 48
    I ordered the jude padding for under the dash with thick rubber covering. It is pre cut for the heater box and has four hole for the bolts. I tried installing it today, 2 of the bolts will not go through all the way. Does that padding go between the firewall and heater core boxes?????
    And the nuts are speed nuts with the tar like material under it???
    Last question
    427 L68 oil line, according to the judging manual it is all steel from block to bracket and from bracket to gauge. I can not find it anywhere for sale. Os the guage correct???
  • Dick W.
    • 10483
    Re: 68 2 Questions heater core and oil line
    C Central # for the line is 303106. Bracket is separate. This is for '69
    Dick Whittington
    • Joseph C.
      • April 1, 2006
      • 48
      is that correct for 68?
      • Dick W.
        • 10483
        I believe that '68 is one year only. I will have to dig up some notes to be sure. I am sure that someone that knows for sure will chime in
        Dick Whittington
        • John C.
          • January 1, 2005
          • 616
          Joe
          Oil line is black plastic in 68.
          John
          • Terry B.
            • August 31, 1999
            • 607
            I believe if you check closely that the oil line in '68 was originally metal. Mine is and it looks to be copper. It does not attract a magnet. It's not plastic.
            Terry Buchanan
            Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
            Corvettes Owned:
            1977 Coupe
            1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
            2003 Electron Blue Coupe
            2019 Torch Red Grand Sport Coupe
            • Dick W.
              • 10483
              Terry, GM never installed a copper line on a Corvette. The copper work hardens from vibration and becomes brittle.
              I believe that John has the correct answer. Plastic in '68
              Dick Whittington
              • Terry B.
                • August 31, 1999
                • 607
                Dick, John & Joe,
                I checked the judging manual for '68-'69 regarding oil lines and found all of us to be partially correct but not completely.
                In 1968, the 427 oil pressure gauge line from the engine fittings to the bracket and from the bracket to the guage is a single natural steel tubing. In 1969, the 427 oil pressure gauge line from the bracket to the engine fitting is steel with a natural finish. The portion of the line from the bracket to the gauge is 1/8 inch outside diameter, black plastic. The small block line in both years is one piece black plastic, 1/8 inch outside diameter, with small white lettering.
                I'm sure someone will be able to tell us why the application of steel vs plastic in those years.
                Terry Buchanan
                Corvettes Owned:
                1977 Coupe
                • Jim T.
                  • March 1, 1993
                  • 5351
                  My original owner 68 SB still has the original black plastic oil line. What should the white lettering on the line be? Have not noticed it?
