Rebuilding C2 Headlight Motors - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    Hi all;
    Was a really crummy weather weekend here in NJ. I used the time to pull the headlight motors out of my 1963....the left hand one had just about stopped working... This was the first time that I have poked around in that space.. Interestingly enough, the motors appear to be original!! One is dated 12/62 and the other just has 63 in the date stamping space.. (the car is March 1963 build)... so I was happy to see that.
    I've read through the archives threads on this topic.. based upon what I have read it would appear that one was rebuilt already (has what appears to be wheel bearing grease in it... a no-no as described) while the other appears to be original (white lithium grease).
    I would like to rebuild these myself.. Can anyone point me to rebuilding/timing instructions?? Even an assembly diagram would be helpful. Evidently there was a Restorer article on this a while back.
    Thanks!!
    Joel
  • Stephen P.
    • September 30, 2002
    • 116
    Re: Rebuilding C2 Headlight Motors
    Try this link:
    http://65corvette.nonethewiser.net/t...or_Rebuild.pdf
    You could also search the archives and find additional info. This is a fairly common topic.
    • Mark P.
      • May 13, 2008
      • 934
      Nice set of directions.
      I did this on my 65 and found it a very satisfying project.
      • Joel T.
        • April 30, 2005
        • 765
        Originally posted by Stephen Phillips (38702)
        Try this link:
        Stephen;
        Perfect! Exactly what I was looking for, Thank you very much!
        Joel
