Sealed Power Part Number - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 269
    Machine shop supplied pistons for rebuild. SP Number L2300F. These for 427/425 which should be 11:1. I wanted to check correct compression on these pistons. Could not find part research on internet. Would anyone have correct ID for this part number.
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Sealed Power Part Number
    Walter,
    Here they are on Summit Racing's web site:
    Free Shipping - Speed Pro ZL2300F with qualifying orders of $109. Shop Pistons at Summit Racing.
    You need the following info to determine the static compression ratio:
    piston dome volume, bore diameter, stroke length, deck clearance, combustion chamber volume, cylinder head gasket compressed thickness, and cylinder head gasket bore diameter.
    Here's a good thread on the topic:
    https://www.forums.ncrs.org/showthre...mcrae&uid=4366
    Joe
