'61 Carpet replacement - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    I have replaced my '61 carpet with Al Knoch carpet. When I go to install the shifter rubber do I cut all of the carpet under the rubber shifter boot away so the the rubber sits directly on the fiberglass? It seems if I don't remove the carpet, the shifter plate will not sit level with the orher side that does not have the rubber boot.
  • Stewart A.
    • April 16, 2008
    • 1035
    Re: '61 Carpet replacement
    Richard if you go to you tube and type in 1960 corvette you will find an installation on carpet it's very lengthy and no sound but you might find your answer there and lots of other tips you might pick up it's from Paragon. Stewy
