The brakes on my 73 were down a bit with a newer set of calipers and master cylinder done about 2 years ago. Probably less then 1500 miles since then. I brought the car down to the local Chevy dealer to see if they could bleed the system. No brake fluid visible anywhere so I wasn't thinking caliper. They seemed to have a hard time bleeding the system and after 2 plus hours the brake was non existent and impossible to drive the car home. They were getting good flow from the front brakes but when they opened the backs it was little more then a spit and air. They tried this repeatedly. They are unsure what the problem is. One person mentioned Master cylinder while another said possibly the proportioning valve. Still another said it should be bled using the brake fluid in a bottle method/tubes to prevent air going back into the system when they opened the bleeders.
What could cause no flow to rt (or left) rear when bleeding? Any ideas what they are doing wrong? Thanks.
