Can someone help me determine how I should refinish my clutch cross shaft on a 1968. It appears that someone may have painted mine with some type of clear so I need to correct. Do you get them zinc plated? Thanks for any insight.
1968 Cross Shaft Finish
Bill Hyndman
The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
1962 Big Brake Fuelie
1965 Fuelie Convertible
1968 L89 Convertible
Tags: None- Top
Re: 1968 Cross Shaft Finish
William-----
I think that originals were galvanized or electro-galvanized. However, this finish is very close to zinc plating, so I don't think that most would be able to tell the difference one way or the other.
The shafts were definitely not clear-coated.
If you have the shaft zinc-plated, you MUST ensure that it is properly annealed subsequent to plating. Otherwise, I can almost assure you that the welds at the lever arms will break in due course.In Appreciation of John Hinckley- Top
to add to joe's comments, they are also a dull finish- bright but not shinny or polished.
Pat
68 427 / 400
88- Top
thanks ver much JoeBill Hyndman
- Top
