1966 horn relay #837 - NCRS Discussion Boards
  • Michael M.
    • February 1, 1993
    • 603
    Over the years I have accumulated alot of used horn relays. I know that the covers can be removed and replated. But what about under the cover does anyone know who restores this part of the relay.
  • Gary B.
    • February 1, 1997
    • 6979
    Michael,
    Check with John Pirkle in Georgia.
    (706) 860-9047
    pirklesr@juno.com or pirklesr@aol.com
      Re: 1966 horn relay #837
      There's not much to 'restore' beneath the cover... You've got a relay contact point that can be cleaned with light/fine wet/dry sandpaper and the magnetic inductor coil. Then, simply misc dust/dirt/grease/oxidation.
      If the inductor coil has 'fried', there's no simple repair. You'd have to either pull it and have it re-wound (few will do this these days) or pull it and install a substitute from a donor relay... Both involve considerable labor.
