I was thinking about buying this Rubbermaid cart from Home Depot:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I like this cart because it's plastic. No rust, easy to clean up. The first job I plan to use it for is holding up my tranny. That's the only item that hasn't moved from my old neighborhood. It's a M-21 restored by 4 Speeds by Darrell, still in the shipping container. The cart has two shelves, is rated 200 pounds max per shelf (400 pounds total). Is the tranny too heavy for the cart? I also plan to have the rear end restored, will the cart be up to the task? I can't think of anything heavier that I might want to use the cart for. Other than that, I will probably use it for parts / tools for whatever job is at hand.
Ideas?
Joe
Ideas?
Joe
I would also use it to move heavy things around the garage and for small projects.
I'll just go ahead and concede victory to you now, it will save us both some trouble! Do you have any more pictures? I am planning to drive my car to the KC national in two years. We'll see. I am close to being done with the electrical. The only circuit left to run is the one for the lift. I've been shooting emails back and forth with Mark Tulley about it.
