1969 headlight assembly installation - NCRS Discussion Boards
  • Charles F.
    • April 30, 2006
    • 99
    Can anyone provide a step-by-step method to install the headlight assemblies in a 1969 with the body on ?
    thanks
    Chuck
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 1969 headlight assembly installation
    Chuck real quick,
    sneak the actuator housings in from the back. then I slide the bearings and stops onto the headlight pivot shafts. Then slide one side pivot shaft into the respective hole and then the other. I forget which side I slide in first but it's pretty self explanitory as you do it. SO what you are doing is holding the front of the headlight door up while the back is snuck in place. Do youself a favor and tape up the opening if you have freash paint.
    Rich
    • Charles F.
      • April 30, 2006
      • 99
      Rich:
      Thanks...mission accomplished.
      Chuck
      • Rich P.
        • January 12, 2009
        • 1361
        Chuck,
        Glad to help!!
        Rich
