Has anyone come up with a good solution to stop the "oozing" of oil from around the filler plug on a Pos. Trac case?
I have drained and refilled the diff. case on my '64 (the oil level is about 1/8 -1/4" below the bottom edge of the filler hole when level)..... I ordered a new cork gasket for the filler plug from LIC .....I've tightened the plug (w/ the "warning plate" in place...) about as tight as I can..... It still oozs......
Has anyone tried using a rubber "O-ring" instead of the cork gasket?
Other options....?????
Garry Eastwood
#38705
Garry Eastwood
#38705
