In my long hunt for decent correct exhaust manifolds the date codes are a smaller "font" size than the part number and I find it very hard to tell any difference in a six from an eight. Is that normal? they both seem to glob up on everything I've seen. What happens in judging?
Exhaust manifold date code castings
Re: Exhaust manifold date code castings
Well, previous owners of the car (70 LT-1) had decided to make the exhaust all 2 1/2" (along with hurst T shifter, Mickey Thompson valve covers, etc) so they took the original exhaust manifolds off and put 2 1/2" ones on. They used 3797901 and 3797902 manifolds which go on 62-65's I believe but, I don't think these are from a Corvette for a few reasons. One is that there are date codes on the front side, not the back. Another reason is I think those dates may or may not say 84 (1984) and not 64 but I've seen so many bad looking sixes and eights I'm not sure what these are. I'm also not sure if the dates were or weren't on the front sides of manifolds back then because C3's are as far back as i've played with. Also, I understand the 3797901 and 02 were also used on trucks, at least from some digging around on the internet has told me.
I do have a repro of the correct 3932461 for that car that I ordered and just like so many i've seen, even on the one I know I ordered right, the six could pass for an 8.
So, I'm probably going to throw them up on Ebay so I can get a little back and not have to hock the fillings in my teeth to finish this car
and don't want to present them as anything but what they are. here's a few pics:
The whole manifold
two different angles on the date code
casting number:
I think if you threw that number nine in the cast upside down and shrunk it you'd see what I'm talking about a six passing for an eight and visa versa- Top
