My antenna bolt hole on is stripped. Before I pulled it I thought I would just helicoil it. Looking at it I am not sure there is enough metal to do so. The walls seem like they must have been pretty thin to begin with and mine is damaged a bit. One of my objectives is to keep the correct bolt.
Is there a home remedy to this? Is a helicoil out of the question as it seems to me? Can/should the hole be filled and re-tapped? If so, how?
Larry
Larry
