1967 voltage regulator location? - NCRS Discussion Boards
  • Mark F.
    • May 11, 2008
    • 68
    Can someone tell me where the voltage regulator is located on a 1967 inner fenderwell. I need the locations of the holes or at least one, to correctly mount a new v/r. I need this due to a new inner fender installed that does not have the holes in it. Thanks guys
  • William S.
    • June 28, 2009
    • 28
    Re: 1967 voltage regulator location?
    Mark,
    Here goes, the location of the upper front hole of the v-a is 17.5 inches rearward from the rear hole of the hinge brkt and 3 inches below the lip on the fender. There just isn't a lot around the area to measure too. If you can find better reference points let me know and I will remeasure.
    Bill
    • Mark F.
      • May 11, 2008
      • 68
      Bill,
      Thank you. Those specs should work fine. However, is it "clocked" in any position? or pretty much parallel to the fender lip/ exh manifolds?
      • William S.
        • June 28, 2009
        • 28
        Mark,
        A line drawn between the front two bolts would be pretty much vertical.
        Bill
        • Mark F.
          • May 11, 2008
          • 68
          Thanks Bill,
          That 's perfect. I appreciate your time.
          Mark
