I'm checking out an AM/FM radio of a fellow member and it looks like his X9 (DS-46) and X10 (DS-501) transistors are toast. I followed the signal path with a scope and checked the voltages and I'm losing the signal from the Collector of X8 (which is hooked to the Base of X9) onwards...
I found on the internet the NTE105 could be a replacement transistor for the DS-501 but are there also known replacements for the DS-46???
Furthermore the speaker isn't producing any sound when a battery is very briefly (100ms) tabbed against the unhooked speaker posts indicating it is dead as well (there was 12V on the speaker posts causing almost 2A running through the speaker due to the blown DS-501).
regards,
Rob.
regards,
Rob.
