72 LT-1 distributor - NCRS Discussion Boards
72 LT-1 distributor
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 72 LT-1 distributor
    Originally posted by Mike Greene (38310)
    what is the difference between a 437-15 and a 437-16 vacuum advance. the book shows the 437-16 to be correct but all of the rebuilt distributors i see have the 437-15. would i get docked points for that?
    There isn't a difference because there is no 437-16. In a recent thread, Terry McM. explained that the 16 resulted from the spec taken from the Delco Test Spec book, which shows 8 distributor degrees max. (or 16 degrees crankshaft equivalent). But all 437's are stamped "15".
      • 15573
      I hope you are right Wayne (that all 437s are stamped -15) because as soon as we put that number in the TIM&JG I expect we will see threads about all the 437-16 that folks have. That is just the way it goes.
      • Mike G.
        • July 31, 2002
        • 709
        #18
        thanks wayne, that should explain why i cant find one and why every car i look at has the 437-15 on it. good to know. i have a nos 437-15 i was going to use if i could not find the correct part. i need to spend more time on here.
        • Wayne M.
          • March 1, 1980
          • 6414
          #19
          Terry --- I've got one too (437_15). Here's my Delco Test Spec book showing the 437 (last line) with the 8 degrees max. distr. vac advance. The asterisk on the column says +/- one degree (distr. degrees), so really Delco is saying that it could give 14 to 18 degrees crank adv. without going out of spec.
