Engine Pad Restamp - NCRS Discussion Boards
Engine Pad Restamp
  • Michael J.
    • January 27, 2009
    • 7073
    Engine Pad Restamp
    In shopping for a big block '66-'67 I found one that obviously has a restamped pad, I think. I am not familiar with BBs, but on the '66 327s I have seen the VIN is just a 6 followed by the last six digits of the VIN. This '66 427 390HP block has a 6, then the S, and then the last six digits of the VIN. That can't be original, can it?
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Engine Pad Restamp
    Doesn't sound right to me.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Steven S.
      • August 29, 2007
      • 571
      I've never seen one with a "S" in VIN stamping, unless someone else can say otherwise, I'd say it's bogus.
      Steve
      • Tom H.
        • December 1, 1993
        • 3440
        I believe regular passenger cars had the plant indicator on the pad, but Corvettes did not in 66.
        Tom Hendricks
        • Larry M.
          • January 1, 1992
          • 2688
          Steve
          Steve:
          I have seen two C2 cars with an S in the VIN stamp number.........both were restamps. Owner's name was Bubba Smith.
          Michael:
          There is no S in the VIN stamp derivative for 1966 for a factory original Corvette. VIN stamp should be seven digits beginning with a 6, followed by a 1 and then the last five digits of the VIN. (ie. 61xxxxx)
          Larry
          • Michael J.
            • January 27, 2009
            • 7073
            Interesting, if the pad stamp is valid, then the VIN may have been changed to match it (from a non-Corvette 427 390 HP car), and if the VIN is valid somebody without much knowledge of Corvette engine pads restamped it in a way that was obviously wrong. Either way it makes one very cautious in buying a Vette without some very detailed examinations and research. I guess it is buyer beware big time.
            • Tom H.
              • December 1, 1993
              • 3440
              Might you have a photo of the stamp in question ???????
              Tom Hendricks
              • Michael J.
                • January 27, 2009
                • 7073
                Sure, it is listed as "numbers matching".
                • Chris E.
                  • November 3, 2006
                  • 1322
                  I'd say numbers matching but not original.
                  Look at the assembly date stamp. MAN is that thing perfect....
                  Chris Enstrom
                  2011 Z06, red/red
                    Director Region V
                    • August 31, 1994
                    • 1464
                    Michael
                    Does that VIN stamp match the stamp on the transmission?
                    HaND
                    • Roy S.
                      Past National Judging Chairman & Concours Team ******
                      • July 31, 1979
                      • 1022
                      Guys do not be surprised if you find out some early 66 VIN derivatives on blocks were stamped with a different holder say from maybe the transmission!!!! Do not be surprised if that is not the case either I often have a vivid imagination.
                      • Tom H.
                        • December 1, 1993
                        • 3440
                        For those of us still needing further education............ do we believe this stamp could be correct with its early VIN ??
                        Tom Hendricks
                        • Michael J.
                          • January 27, 2009
                          • 7073
                          Originally posted by Mike Murray (25129)
                          Michael
                          HaND
                          I haven't looked that far after the obviously bogus engine stamp. But guess for chuckles I could. The price on the car has been reduced, wonder why?
                          • William C.
                            • May 31, 1975
                            • 6037
                            I dn't have the info handy right now, but I believe I remember a discussion regarding the assy plant being instructed by engineering to add the "s" to either the engine or Trans stamps for the start of a model, causing some major aggrivation at St louis. I little jumping up and down hollering session caused the requirement to be recinded, but I don't have the details available at this time. I'd probably take a hard look at the pad machining, and if "old broached" likely buy it on an early '66, just my opinion.
                            Bill Clupper #618
                              Director Region V
                              • August 31, 1994
                              • 1464
                              Michael,
                              "obviousloy bogus re-stamp" based on?????
                              Please do and if original to the car, post a pic of the trans stamp, if you would.
                              HaND
