1959 Soft top deck lid. - NCRS Discussion Boards
  • Stephen R.
    • May 20, 2008
    • 302
    I have, what I thought, are two original soft top deck lids. I was taking the paint off of them and I noticed that the attachment areas, where the male half of the locking mechanism is (the area that goes down between the seat and above the center glove box) are different. One has a large hole in it, with a smaller hole for a screw. The other is completely untouched, no large hole or screw hole and no repair whatever.
    Were the deck lids different for different years?
    Pis attached.
  • Bill M.
    • April 1, 1977
    • 1386
    Re: 1959 Soft top deck lid.
    Pis attached.
    The original lid for car '59 2528 has the big hole.
    • Stephen R.
      • May 20, 2008
      • 302
      Bill:
      Don't quite understand your answer. Are you indicating that from car (1959) #2528 onward they had the large hole? How was the bracket attached on the lids without the smaller screw hole?
      Steve
      • Bill M.
        • April 1, 1977
        • 1386
        Bill:
        Steve
        Steve:
        Hope this helps.
        Bill
        • Doug F.
          • November 1, 1983
          • 322
          LH lid is a 56/57 while it will fit a 58-60 it takes the hook style latch, the RH lid is the 58-60 which uses the male female type latch
          • Stephen R.
            • May 20, 2008
            • 302
            Thanks Doug, now I get it.
              Steve -
              Here's a '57 lid - matches your LH photo.
              • Stephen R.
                • May 20, 2008
                • 302
                Thanks John. I checked around, apparently the male half of the latch for the 57 is reproduced but the female half isn't. I may just convert the 57 deck lid to a 59.
                • Steven B.
                  • June 30, 1982
                  • 3976
                  Try Grossmueller's, MaryJo Rohner, and others specializing in used parts. '57 covers are getting hard to obtain.
                  Steve
                  • Stephen R.
                    • May 20, 2008
                    • 302
                    Thanks again for the advice. Apparently, there is some interest in this lid as a 57. I may keep it as is. It's not in that good a condition, however. It appears that someone stepped on or something fell on, the driver side soft top clamp area. There is circular crazing in the fiber glass around the clamp hole and the underneath rear rail by the driver side hinge is severely cracked and will need major fiber glass surgery to get it stable again. There is also a small minor crack by the other hinge.
                    • Valeria H.
                      • July 27, 2009
                      • 463
                      John, looking at the photo of your cars deck lid I am noticing your convertible top tabs jutting out from the deck lid with what looks like metal rods going through the center of the tabs coated with foam padding. Is this what I am seeing? I only have the pads. What am I missing?
                      Valeria
                      Valeria Hutchinson
                      Past Chairman of the Carolinas Chapter
                      1960 Roman Red w/ White Coves -"Bella"
                      2005 Millennium Yellow 6 speed 400 HP - "Trixie"
                      • Stephen R.
                        • May 20, 2008
                        • 302
                        Actually, I noticed that myself, mine just flop down. What do yours have that keep them erect........(ok guys have fun with this)
                          Valeria
                          Valeria -
                          Nope, no metal rods or foam - just the slider retainers at the forward end; they're reproductions, and they aren't very "supple".
                          • Valeria H.
                            • July 27, 2009
                            • 463
                            I'm there with you Stephen!! John, what is your secret for your erect soft top vinyl covers??? Mine do not look that full or stiff, in fact they are really limp. Am I missing something?
                            Valeria
                            Valeria Hutchinson
                              Valeria
                              Valeria -
                              Yours are probably original (or better reproductions than I had); originals were quite supple.
