C1 preferred fluids - NCRS Discussion Boards
C1 preferred fluids
  • Valeria H.
    • July 27, 2009
    • 463
    C1 preferred fluids
    I am revisiting the question of what fluids are recommended for C1 cars. The only post in the archives regarding this issue was offered in 2003.
    What oil, antifreeze, brake fluid do you prefer and why?
    Thanks in advance for your comments
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Jean C.
    • June 30, 2003
    • 688
    Re: C1 preferred fluids
    Valeria,
    Search posts by Duke Williams and you will find a complete library on motor oil recommendation.
    Best regards,
      • 15610
      Read the following article (begins on page 3 of the pdf), which was originally published in the Summer 2008 Corvette Restorer and become your own engine oil expert and decision maker for any vehicle/equipment you own.
      Network Solutions - Original domain name registration and reservation services with variety of internet-related business offerings. Quick, dependable and reliable.
      For vintage Corvettes I recommend Zerex G-05 antifreeze mixed 50/50 with distilled water. The archives are full of all the whys and wherefores along with explanations of antifreeze corrosion inhibitor chemistries - IAT, OAT, and HOAT.
      Use DOT 3 or DOT 4 brake fluid for normal servicing, and do a system flush every 2-5 years depending on climate, driving and storage conditions. Don't use DOT 5 unless you start with a completely clean and dry system including the master and wheel cylinders/calipers.
      There have been extensive discussions on all of these subjects going back to the beginning of the TDB, circa 1999, and no stone has been left unturned.
      • Valeria H.
        • July 27, 2009
        • 463
        Thank you for sharing your wealth of knowledge on the subject!
        Valeria
        Valeria Hutchinson
