1965 water pump pulley - NCRS Discussion Boards
  • William G.
    • April 1, 1978
    • 154
    What is the correct water pump pulley for a 1965 L75 with air and power steering
    Could someone post a picture of one.
    What is the correct fan blade and what does it look like.
    If possible post a picture.
    THANKS
    BILL
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1965 water pump pulley
    THANKS
    BILL
    Here's the fan #3853943, with 7 blades and distinctive tip geometry. Maybe others can say what pulley with base engine or L75 C60.
      THANKS
      BILL
      Bill-----
      The pulley was GM #3850680. It was replaced by GM #3890419 and, later, by GM #3995643. The latter was available until fairly recently, but is no more.
      • William G.
        • April 1, 1978
        • 154
        Thanks Wayne and Joe
        question. Was the pulley on the crank 2 grooves or 3
        and do you know the part # on a L75 w/ac and p/s
        Bill
          Bill
          Bill-----
          I believe the application used 2 pullies, sandwiched together. The inner pulley was a 2 groove pulley of 7.33" OD and GM #3850838. The outer pulley was a 1 groove pulley of 6.69" OD and GM #3751232.
          The 3751232 is still available from GM. The 3850838 was discontinued without supercession more than 20 years ago, but is available in reproduction.
          • Mike G.
            • January 1, 1991
            • 418
            Question Joe on the -838 Crank Pulley
            I also have a 1965 L75 with A/C and P/S. When I researched pulley p/n's, I saw the -838 listed in the parts catalogs as the correct one for A/C. Makes sense, since the bigger diameter will move more coolant & air.
            But.... I couldn't find anything in the AIM that changed the crank pulley from the base 3744043 for either L75, C60 or N40. Maybe I'm missing a page --wouldn't be the first time.
            • William G.
              • April 1, 1978
              • 154
              The pulley that was on my water pump was a 2 groove with the
              part # 35168 and not sure about the next # believe to be a 9
              Was the 608 pulley used on any other chev
              Bill
                Re: Question Joe on the -838 Crank Pulley
                Mike-----
                I don't think you're missing a page. The AIM is "silent" on the rear pulley used for the L-75 with C-60 and N-40 application. This may mean that it's the same as used in the base configuration OR it could just mean that they're "silent" on it.
                I would not rule out, though, that the 3744043 was used for the L-75 with C-60 and N-40 application. However, that's contrary to the information I have, keeping in mind that my information on this is not empirical.
                The 3850838 part number is consistent with a late 1964 or 1965-released part. So, it would have been available for use for 1965 (but not much earlier). Also, it definitely was used for many later, small block C-60 applications.
                Incidentally, the GM #3744043 pulley had a "strange" history. It was released about 1958. However, it was then known in SERVICE as GM #3747479 although it was apparently stamped 3744043. In December, 1971 the 3747479 part number was dropped and replaced by GM #3744043. So, finally, the "confusion" was ended. In fact, it's still available from GM to this day under that number-----a part that's been essentially continuously available from GM for over 51 years!!!
                  On the crank the pulley is a 2 groove pulley dont know the part #
                  will pull off later.
                  Bill
                  Bill------
                  There was once a waterpump pulley of GM #351680. However, it was never originally installed on any Corvette, especially a 1965 Corvette. That's because it was not even "born" yet when your car was built.
                  GM #351680 was a fourth generational supercessive part number for what was originally GM #3932430. The latter was a pulley used for many 1969 and 1970 Chevrolet passenger cars, Chevelles, and Camaros with C-60. It was superceded by GM #3976059, 3995631 and then, in 1977 by GM #351680. Later, GM #351680 was replaced by GM #14023155 which remains available from GM to this very day. NONE of these pullies was ever originally used on a Corvette or, even, ever cataloged in SERVICE for a Corvette.
                  It's amazing how these cars get "insulted" by the installation of even functionally incorrect parts over the years.
                    Bill
                    Bill------
                    I overlooked this part of your question. The GM #3850680 pulley was used for many 1964-65 Chevrolet passenger cars, Chevelles, Camaros, and Chevy II's, with and without C-60. However, it led a fairly short life. First used for the 1964 model year, it was replaced by the 3890419 for the 1966 model year and discontinued from 64-65 SERVICE and replaced by the 3890419 in June, 1966.
