I have a '68 Corvette 327/300 HP engine with the short water pump which I understand limits the options for clutch fans for some reason. I have had several of the stock Corvette hydraulic clutch fans go bad on me by leaking fluid or simply being out of balance.
My question is how have others solved this problem? What other options might be available to solve this continuing problem? What is the part number for the OEM short water pump hydraulic clutch fan? Where can I get a properly balanced OEM style replacement?
Any help will be greatly appreciated.
Can you recommend a good shop to properly balance the OEM fan assembly?
