C2 B Pillar Configuration - NCRS Discussion Boards
  • John P.
    • May 25, 2009
    • 17
    Does anyone have any photo's of the C2 birdcage B pillar in the area of the gutter/water deflector? I am uncertain of the ccorrect configuration and would appreciate any help. Thanks.
  • Dale O.
    • May 31, 1995
    • 52
    Re: C2 B Pillar Configuration
    John,
    Thats pretty bad. Although not as bad, I had a similar problem on my 65. I took a lot of photos of the repair process. When I get home this evening I will look to see if I have what you need and post. I was able to complete a repair on the area by cutting out the rust and replacing with the appropriate guage sheet metal. You may be better off finding donor birdcage parts in your case.
    Dale
      John -
      See page 66 in Noland's book.
      • John P.
        • May 25, 2009
        • 17
        Thanks guys. It's the configuration of the actual birdcage that I am interested in. I removed the damaged portion of the B pillar for ease of repair. I'd appreciate any photo's of this specific area. Thanks again.
        • Douglas L.
          • August 31, 2003
          • 299
          John,
          Check out this link - hope it helps you.
          404 page not found - provides a one stop performance shop for the Northwest! We provide professional installation, diagnostics, set-up and tuning for your Corvette. Whatever you need - From an oil change to HP gains. We are your source for all your Corvette needs.
          Doug Lee
          • Wayne W.
            • April 30, 1982
            • 3605
            some pics.
            • John P.
              • May 25, 2009
              • 17
              Guys, that's it! Between the web page and the pictures I should be able to put the B pillar back the way it was intended. Thanks!
              • John P.
                • May 25, 2009
                • 17
                The upper B pillar was successfully rebuilt and has been reinstalled. Thanks for the pictures.
