Undercoat removal - NCRS Discussion Boards
Undercoat removal
  • Dale C.
    • November 1, 1999
    • 844
    Undercoat removal
    Is it possible to remove undercoat and save the sometime job number chalk marking in the right front wheel well, if there? See Pro Team L88 picture. How so if it can be done?
  • Stewart A.
    • April 16, 2008
    • 1035
    Re: Undercoat removal
    No way remove that paint. You could always cover it and work around it, I would leave it alone. That would be my intention. You probably could do it but I wouldn't risk it. Is it chalk or crayon by the way. Stewy
      • 11608
      Dale,
      I'm quite sure that the undercoating is supposed to be there.
      You'd be removing one original item to show another one.
      Patrick
      • Stewart A.
        • April 16, 2008
        • 1035
        Are we talking about the external finish on the inner guard or the undercoat. Or sound proofing paint which I'm not sure if the L88 has. Stewy
        • Dale S.
          • November 12, 2007
          • 1224
          If we are talking about 1967, the writing must be crayon. I discovered mine while washing off the road grime with soap and water. I am sure chalk would have been gone. There was no undercoat in that location on my Calif. delivered car. Dale
          • Page C.
            • February 1, 1979
            • 802
            The factory undercoating in the wheel wells was applied before the car was blacked out. That undercoating is almost impossible to dulpicate today. Most aftermarket undercoating is a rubberizes material that is NOT correct. I would clean with something like Simple Green and a soft brush and recoat with the black out paint of your choice.
            Page Campbell
