64 hood with a 63 base - NCRS Discussion Boards
  • Philip C.
    • December 1, 1984
    • 1117
    Hi everyone I have a friends car that I am helping him out with. I noticed that the hood has the four mounts for the hood blocks that the mid to late 63 hoods have, has anyone else seen this Thanks Phil 8063
  • Boyan B.
    • August 31, 1999
    • 187
    Re: 64 hood with a 63 base
    Phil, yes this is semi-common. It usually occured with early 64's, but I have seen a Dec 63 car built with one. I don't know if it was changed with an earlier hood, but it looked like it was original. I have run across several early 64's with this.
    Boyan
    • Todd B.
      • February 1, 2005
      • 59
      My early (#347) '64 has that type of hood construction as well.
      Todd
      • Philip C.
        • December 1, 1984
        • 1117
        Boyan
        Thanks Boyan, good to hear it happen. I dont know where you got it was a Dec built car, it was built in Oct 63. Thanks again Phil
        • Philip C.
          • December 1, 1984
          • 1117
          Todd
          Thanks Todd, great photo Phil 8063
          • Bill C.
            • May 31, 1989
            • 424
            Phil,
            I have seen it quite a few times also.
            Bill Caldwell
            • Paul J.
              • September 9, 2008
              • 2091
              My Oct. 63 car has it also.
              Paul
              • Michael H.
                • January 29, 2008
                • 7477
                Paul
                Paul...
                Just curious, since you have an early production 64. By chance, did the car have 63 coil and leaf springs or are they the later 64 style?
                • Paul J.
                  • September 9, 2008
                  • 2091
                  Originally posted by Michael Hanson (4067)
                  Paul...
                  I'm about three weeks from pulling the body, so I haven't studied the springs yet. I'm ignorant of the differences between 63 and 64. Tell me what I should look for and I'll check.
                    Paul -
                    '63 front springs were constant-rate, evenly wound (same gap between coils the full length of the spring in the free state). '63 rear spring had 9 leaves, all 9 were cambered.
                    '64 front springs were variable-rate, progressively wound (closer coil spacing at one end than the other in the free state). '64 rear spring had 9 leaves, but only the bottom six were cambered - the top three were flat.
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      Paul -
                      The springs are still in the car with the body on, so it's difficult to tell, but the top three leaves of the rear spring are flat. On the front I'm not so sure. With the weight off the wheel it looks like there may be some progression in the coils but it is hard to judge. They'll be out of the frame next year.
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Thanks Paul. I'm just trying to figure out when in 64 production the new variable rate springs first appeared. I guess there are several early(Sept 63) 64 builds that reported having these 63 springs but I don't know how long this continued in production.
