1966 427 a/c compessor brackets-need a photo - NCRS Discussion Boards
  • Bill C.
    • May 31, 1989
    • 424
    Hi,
    Anyone have some pics of 1966 only BB 427 air conditioning compressor mounting brackets? I understand they are unique to 1966? I think the difference may be the lowers only. Can anyone shed light on this?
    Bill Caldwell
  • Page C.
    • February 1, 1979
    • 802
    Re: 1966 427 a/c compessor brackets-need a photo
    Hi Bill,
    I have a the following brackets from a 1966 big block Corvette with the following CASTING numbers:
    3887165 lower rear bracket that bolts to exhaust manifold
    3887166 lower front bracket
    3872726 upper bracket that bolts to intake manifold-also the brace that bolts to this bracket.
    The front bracket that bolts to the compressor(no casting #)
    Send me your email and will send you some photos
    Page Campbell
    pcampbell3618@comcast.net
    • Bill C.
      • May 31, 1989
      • 424
      Page,
      Thanks, very interested, I sent you am email with my email address, although its the same one available from this site.
      Thanks !
      Bill Caldwell
      • Page C.
        • February 1, 1979
        • 802
        I am going to try and post some pictures of the 1966 Big Block air compressor brackets.
        Page Campbell
        • Page C.
          • February 1, 1979
          • 802
          It worked. OK a few more:
          • Bill C.
            • May 31, 1989
            • 424
            Pretty interesting, the front and rear lowers are the only ones different from the 67-up counterparts, although very similar, especially the rear one.
            The front stamped steel one is identical the the one used on all 64-75 small blocks, including passenger cars, etc as far as I know. The top rear support bar type bracket and the cast one that bolts to the intake are the same as 67-up.It appears the front lower cast one from 66 only has an additional boss on it with a threaded hole that allows the use of the small block stamped one.
            The 67-up front lower does not have that feature as its not needed with the new design stamped bracket for 67-up BB's.
            Anybody know why this change was made? I wonder if it lowers the compressor location, remember, they made special valve covers for a short time also anticipating bracket clearance, turned out to be unneeded and eliminated. I seem to remember those appear around Nov 65 and are pretty much gone by Jan 66.
            Another detail they were juggling on the 66 427 a/c design.
            I wonder if the 66 BB lower two unique brackets are Corvette application only?
            Wish I still had my 65 BB a/c SS Conv Impala, I could have looked
            Thanks very much Page for making the effort to post these pics, now if I can only get you to release your grip on 'em!
