Rear deck hinge color on 69 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    What color is the hinge brackets and springs in a 69 convertible deck?
    Where does the body color stop?
    Attached is area of question.
    Thanks in advance.
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Pat M.
    • April 1, 2006
    • 1575
    Re: Rear deck hinge color on 69
    Hi Ralph. Check out this recent photo from my 70:
    https://www.forums.ncrs.org/showthre...48659&uid=3554
    It's not the best at showing your point of inquiry, but as you can see both the brackets and the springs are poor quality body color, and I would assume your 69 should be similar. I was never told mine was incorrect in judging. Good Luck
      The deck lid was mounted to its hinge bracket with springs in place when the body whent through the paint booth. Since the underside of the deck lid was shot with body color, the supporting hinge assy's also received spray.
      Where does the color stop? That's a variable. It depended on the aggressiveness of the painter and the amount of airborne overspray present on that particular paint job. Most show SOME sign of radom overspray all the way to the bottom of the hinge support assy with coverage thinning out the further away from the bottom side of the deck lid you go down the hinge assy...
      • John C.
        • January 1, 2005
        • 616
        Ralph
        Attached are a couple pictures of my 68 in the same area you show.
        My 69 looks the same but it is a green car and the bracket and hinge appear to be black so there is very little contrast you can see.
        Once the carpet is in place very little of this area can be seen. My 69 carpet covers this area even more then is shown in the 68 pictures.
        John
