I was cruising my '65 small block convertible on the highway yesterday at about 65 MPH and experienced some mild side-to-side sway coming from the back end of the car. I have owned the car for about 18 months and never had that strange sensation before. It didn't happen all the time, but I felt it on and off a few times during my drive (about 30 minutes each direction). I believe that the suspension is stock; although I am sure that many items have been replaced over the years. My 215/70R-15 Yokahama radial tires have only 1,500 miles on them and are mounted on knock-off wheels. When I had my clutch, tranny mount, and driveshaft universal joint replaced about 900 miles ago, the mechanic told me that I should replace one shock absorber, and that one of the rear yokes (half shaft) had a little too much play. However, he said that both would be fine for awhile and didn't require immediate repair or replacement. Could either of these be causing my sway issue, or might it be something else? I have noticed a crunching/squeaking sound when I get in and out of the car (or just push down on the car) as if something needs to be greased. I read through the archives, but didn't find a thread with my same issues. Duke and others have provided a lot of information about tires and shocks, but I want to know if shocks alone could cause my problem or if it might be another suspension component. It gives me an uneasy feeling when driving in a straight line on the highway and I feel the back of the car developing "the shakes" (gives me the shakes, too)!
Your thoughts are appreciated,
Roger (50141)
Roger (50141)
