c2 moulding clips do not hold - NCRS Discussion Boards
  • Dennis G.
    • March 1, 2000
    • 2
    clips from corvette central will not hold down moulding on windshil and coupe back trim Help
  • Scott S.
    • September 11, 2009
    • 1961
    Re: c2 moulding clips do not hold
    Hi Dennis,
    I knew I was going to have to cross this bridge at some point myself, so when I came across information about it, I took notes. Someone on another forum asked a similar question about replacing a midyear windshield in March of 2008, and John Hinckley replied with the following:
    "You'll need a new weatherstrip/seal (Corvette Rubber), and you'll probably find at least some of the molding retainer clips corroded/broken; get replacements from Paragon - theirs are the only ones that work. The clips can only be replaced when the windshield is out of the car." (JohnZ, post 2, 03-08-08)
    Hope this helps,
    Scott
