1963 Replacement Shocks - NCRS Correct? - NCRS Discussion Boards
  • Joseph E.
    Infrequent User
    • January 2, 2009
    • 19
    I've read the latest 63-64 Judging Guide and know what the original front and rear shocks were for my SWC (base engine). What I'm wondering is if there are replacement shocks out there today that pass NCRS standards? If so, who has sells them? Thanks very much.
    Re: 1963 Replacement Shocks - NCRS Correct?
    Most shocks will 'pass' judging scrutiny with some level of deduction. If you meant to ask if there are shocks available that you can write a check for that are 100% PERFECT reproductions of the factory original parts, the answer is no...
    • Peter B.
      • March 28, 2007
      • 90
      Joseph,
      Here's a link that I found in a search of the Archives under "C2 shocks", it has a lot of info including what appears to be an acceptable AC Delco shock. https://www.forums.ncrs.org/showthre...hocks&uid=7336
      You can also check out the Advertisers listed under the link at the top of this page.
      You'll probably get a specific answer from one of the other members...there's a huge knowledge base residing on this forum.
      Hope this helps.
      Pete
      • John D.
        • June 30, 1991
        • 874
        Joseph,
        Before you spend a lot of money keep in mind they are hard to see when installed and it's very difficult to check for numbers and dates as some chassis judges (this one included) are not as svelte as we used to be....
