During recent NCRS meet, I was told by a judge that my 1970 Corvette (350/350 HP) was missing a support that supports the vacuum advance tube running from the carb to the TCS valve. Most of the literature that I have does not show this support as being original for an L46. I will, of course, go with the judge's decision, but wondered what other 1970 owners have on their cars. I was also told that the distributor tag should be red rather than "aluminum" colored. I thought some could be red and some could be bare aluminum. Can someone straighten me out?
Vacuum Advance Tube Support
Re: Vacuum Advance Tube Support
Usually one side of the distributor band is tinted red, the other is natural.
The red side may be toward the inside, but is most often toward the oustide and visible. The judge(s) "should" have looked to see if there was red present on either surface.
I do not see the clip noted on any of the cars pictured in Dobbins' book.
As you have learned, just because a judge makes a deduction does not mean that they were correct.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Duane, I don't know the particulars for your 70 (My 71 350/270 has the clip for the vacuum tube) but for the distributor tag, I also show the aluminum side exposed (red on opposite side) for the original tag on mine.
I hope others with the same situation will chime in because we are led to believe this is incorrect. Mike- Top
Thanks Warren, and Duane you are correct. They could have either side exposed. The TIM&JG does state that but goes on to state " On 70-72 Corvettes, the overwhelming majority of bands have the red side out".
Mike- Top
During recent NCRS meet, I was told by a judge that my 1970 Corvette (350/350 HP) was missing a support that supports the vacuum advance tube running from the carb to the TCS valve. Most of the literature that I have does not show this support as being original for an L46. I will, of course, go with the judge's decision, but wondered what other 1970 owners have on their cars. Can someone straighten me out?
- Top
Mine is configured like Dennis' picture with no clip, but I have seen later production in 1970 which had a clip. Here's a pic from the Del Val meet that shows the clip - hard to see behind the wire. This car had the later closed air cleaner and was completely restored.
- Top
As far as Greg's photo,(good pic), I suspect the later L-46(closed A/C) also had a different advance tube, as the bends in the photo would indicate. Could be 71 setup for late 70's? That setup I am not familiar with.
Someone did mention to me that the closed air cleaner's tube needed to exit and bend down sooner for clearance. I put some faith in that since I always notice the small rubber hose, (exiting the carb to the tube), a bit bent down from the open A/C base pressing on it.- Top
Also note that the TCS "appears" to have a black rubber cap on it - not foam as was originally installed.
All 3 ports(nipples), on the 70 solenoid are used, so none would have a foam filter as the 71 piece I noticed in your great collection of photo's .- Top
Wow, what a good discussion. I plan to leave my 70 L46 without the support clip. I noticed that the Dr. Rebuild catalog, which shows many vacuum tube configurations for 1970-1972 engine options, doesn't show a support clip for the 350/350 engine. He does show a clip for the 1971 270 HP engine; however the TCS valve is in a different location on the 1971. Happy Thanksgiving everyone.- Top
Let's face it, unless some nut like me is just obsessed about it, there ain't a whole lot of money to be had for a vender with this one .- Top
