I am replacing the original 1542 Hyatt bearing on my 62. I see in previous posts that the 607 is wider and you do not need the spacer with this bearing.
Will I need to take the axle somewhere to remove the seal in order to get the bearing off? Or is there a way I can remove it and install the new one?
Also, one side of the new bearing looks completely sealed while the other seems to be slightly open. Does the slightly open side go toward the housing so lube gets to the bearing?
I actually think the minor leak I have is because the single O ring is flat as a pancake. The bearing itself seems ok. There seems to be a very minor space, maybe 1/32nd or so where I can move the bearing on the shaft. Shouldn't the seal be up tight against the bearing?
Any help or direction will be greatly appreciated.
Bob
Bob
