My car is at my brother's shop and his mechanics will be making the side yoke repair on my differential and replacing some rear suspension bushings on Friday. While it's on the lift, I thought it would be a good time to address an issue that has been annoying me for a while. About a year ago, I had a new Centerforce clutch & pressure plate installed, as well as a couple of transmission seals replaced. It took some getting used to the new clutch as it released much higher than the old one. However, now my shifting transition between 1st & 2nd and 2nd & 3rd gears is harder - with a "kick" - than I think it should be. It is unlike the smooth, effortless transition that I experience between 3rd & 4th gears. The transmission itself shifts fine, so my guess is that the culprit is a clutch adjustment issue. What do you guys think? Now is a good time to deal with it while the car is lifted and mechanics are hovering below.
Your thoughts are appreciated,
Roger (50141)
Roger (50141)
