I recently purchased a 1972 convertible LT1. I got the car with its original window sticker, Corvette Order Copy and Protecto-Plate as well as the original dealer order sheet. The car was ordered with the ZW4 wide-ratio transmission and 3.55 "standard" rear gears per the dealer order sheet. The Corvette Order Copy and the Protecto-Plate (as well as the matching rear-end in the car) reflect that the car was equipped with a 3.70 rear ratio, which I understand from the Powertrain chart to be the "performance" rear axle ratio for the M-20, wide-ratio transmission in the 1972 Corvette LT1. My question relates to the fact that this rear-axle ratio is not mentioned on the window sticker as a ZQ9 "Performance Axle Ratio" option or called out in any way on the window sticker, I was thinking that the 3.70 ratio would have been annotated on the window sticker. Is there a chance that it was somehow missed or is there another reason why this would not have been annotated on the window sticker? Thanks in advance for any thoughts or ideas.
