Hey All,
I recently bought an AC compressor that was listed as a 1967 compressor dated February 67. I started checking out all of the numbers on the unit and had a couple of questions. The head plate (see pic) is stamped:
B67 (February 6, 1967)
R 4 (not sure about this)
6555302 (head plate part number)
Sticker had:
5910645 for model number which seems correct for 1967
although the serial number was worn off, I could make out the numbers that had been original stamped into the foil label - 021571 which translates into February 15, 1967; 1st shift
also on the front at the base of the pulley near the electrical input another number was stamped 50/655283 (this a part number but not sure to what yet).
So, questions
The, what appears to be original label, seems to marked correctly for a real 1967 AC compressor. All the wear and rust marks suggest the label is original.
The head plate seems to be marked B67 for Feb 6, 1967 which puts it ahead of the foil label and correct by NCRS judging book.
But, the head plate part number 6555302 can be found in the Corvette Parts Catalogue on page 9-3 under 9.174 and is listed as a 1978 Y (Axial) (Non Super Heat Type) (1st Des). So, I'm confused.
Lots of previous posts by other C2 owners have listed this same head plate number 6555302 as being on their compressors as well. What is going on here?
Sticker had:
So, questions
]. Assuming that the model number is 6550133, and the back head is cast "C"236 (not zero); ie March 23'rd 1966. The date format decodes as: March (03) 29th "6" = 1966; 2= second shift.
