This should be simple, and it probably is, but I have spent enough time on it that it's time to ask the experts.
1967 Coupe (Jan. 11, 1967)
L79 engine, "HT" engine pad suffix, with factory A/C (not sure if that would affect the exhaust manifold or not)
The first question is about the RH manifold.
Using the "Corvette by the Numbers" book as my guide, and the 1967 Judging Guide, I was able to identify the correct RH exhaust manifold. It reads 3747042, then below that number is "RH", and immediately to the right is "4 9", which also appears on the back side.
The JG says "no visible casting dates appear on original exhaust manifolds.", while "Corvette by the Numbers" seems to say there ARE casting dates.
Is this an original 327/350 (1967) exhaust manifold, (pictures below) and what does the "4 9" mean?
