This is a strange question, but I was examining the original dual reservoir brake master cylinder from the '67 L79 coupe last night, and looking at the Brake Warning Light Switch looking for dates. The switch is described in Noland Adam's book on page 388 and in the NCRS judging guide.
Two things caught my attention. The "date" on mine (if that's what it is) is "7 8 1", the same as "many" were found to be in Noland Adam's research. However, if that is indeed a Julian date code for 1967, 81st day, then it can't be original to the car, because if I understand correctly, the build date for the car is January 11, 1967. It has "F11" on the Trim Tag, and using the available Internet birthday calculators, I come up with the same date by searching the VIN.
Then I noticed that there is a heart-shaped "stamp" on the outer casing, facing outward toward the driver's side when mounted on the car. Does anyone else have this heart-shaped stamp on their Brake Warning Light Switch?
I have a suspicion about it, but I wanted to find out if anyone else has this mark, and what it might mean, before I jump to any conclusions.
Thank you,
Scott
Thank you,
Scott
) what I believe was a Julian date code of "2 1 0 6", which should mean the 210th day of 1966 (see picture). In a slightly different format, the seat-belt tags have what might be called a Julian-style date of "50 E 66" for the 50th week of 1966.
