Now that I have the tunnel insulation, engine and transmission installed, can somebody tell me where the backup switch pigtail goes? In other words, does it go underneath the insulation?
Backup light switch wiring
Re: Backup light switch wiring
Dennis------
It does not install under the insulation.In Appreciation of John Hinckley- Top
Henry
My car is a '69 so I looked thru the '69 AIM and can see where the pigtail is probably held by the clip on the driver side firewall, the one that holds the speedo cable as it leaves the firewall grommet. That looks like where it is going to hang. Thanks.
Dennis- Top
Oops, sorry Dennis. I had a brain fart, didn't even notice your yellow 69 in your avatar!! Wasn't sure what the 69 AIM shows.Henry
Dennis- Top
Henry
Quite all right. I found a small empty clip a little lower on the firewall, right where the tunnel starts. I knew that clip protruded thru the insulation for a reason. I am sure that is where the pigtail gets supported.- Top
