68 grill bracket color and rivit - NCRS Discussion Boards
  • Brett W.
    • November 5, 2009
    • 24
    Could someone tell me if the rivits on this bracket are original? And what color should the brackets be. . The rivits on the other side are regular pop rivits so I know they are replaced. I also saw in the history posts that the rivits will be painted, as the brackets were put on before paint. So mabey the overspray is from the factory. I don't want to mess them up thanks.
    Brett
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 68 grill bracket color and rivit
    Brett,
    Your car looks original. The bracket was in place at painting, so body color and black out appear correct.
      • 15573
      It looks like body color overspray on the wires in the first picture, but it could be a reflection. I can assure you there was no body color overspray on the wires at the factory. Well maybe I should say it is unlikely there was body color overspray on the wires from the factory.
      • Jack C.
        • September 30, 1992
        • 1090
        I agree with Terry. rivets look good, overspray doesn't
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Dale C.
          • November 1, 1999
          • 844
          Brett
          Dale
          • Brett W.
            • November 5, 2009
            • 24
            Originally posted by Dale Carlson (33147)
            Brett
            Dale
            No, someone used alum pop rivits on the drivers side. There must have been a earler repair. It's interesting that the drivers side on you're car can't be seen?
            • Brett W.
              • November 5, 2009
              • 24
              Yes that is overspray on the wires also. I found that the car was repainted 13 years ago. I think all the overspray is new. I wasn't shure if i should repaint the brackets to clean them up, or leave them alone.
              • Dale C.
                • November 1, 1999
                • 844
                Does anyone else have a picture of the underside of the drivers side? Or pictures of both undersides?
                Dale
                • Brett W.
                  • November 5, 2009
                  • 24
                  Are the rivits still avalable, if not what is a exceptable replacement for judging. I have seen the rivits that look like them but have a nut on the inside.
