Wire routing and license plate light ground - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    The harness for the turn signal wire comes out of the fuse box and the end connector clips to the steering column. Do these wires go over or under the clutch push rod? A photo would be helpful
    The shop manual shows the ground for the license plate light attaching to the light assembly. Does one of the mounting screws go through the light assembly, then through the ground terminal then into the clip nut?
    I have looked at the shop manual and the assembly manual but it is not clear.
    Mike
    Re: Wire routing and license plate light ground
    Mike
    Mike -
    That part of the harness routes above the hood release cable and the clutch pushrod. The license light ground is attached as you noted.
    • Jim D.
      • 2882
      Mike,
      I would look at my 65 but it's close to 15 degrees out and that's toooooooo damn cold to go up to my shop and look. If nobody answers, I'll go look tomorrow.
      Jim
      Oops, John beat me to it.
      • Mike R.
        • August 30, 2009
        • 321
        Thanks John!
        Mike -
        • Mike R.
          • August 30, 2009
          • 321
          Thanks Jim, it looks like I have the answers. BTW I heat my hanger to about 35 deg. I recently bought insulated coveralls and fingerless gloves which help a lot.
          Mike
          Originally posted by Jim Durham (8797)
          Mike,
          Jim
